I am running into an issue with a Honeybee-Energy model, trying to use the default HVAC Systems. I wonder if this is a known issue or if there is a fix? Or if I am doing something incorrectly?
My scene simulates just fine with IdealAirLoads, but if I try and use any of the Honeybee-Energy HVAC Systems (AllAir, DOAS, HeatCool), I get the error:
SWIG director method error. NoMethodError: undefined method `thermal_zone_heated?’
and the run fails as a result. Has anyone seen that before? I searched the forum here but don’t see any references to this type of error before?
Example Model (single zone, units=meters):
IdealAir Runs Fine:
HVAC Templates Fail with the Above Error:
Versions appear to be all up to date?
Attached are the example GH file, for reference, as well as a record of the run with the run.log which has the entire error.
hbe_test_run.zip (1.2 MB)
hb_e_test.gh (53.2 KB)
Environment:
- Apple M1 (ARM)
- MacOS Sonoma 14.6.1
- Rhino v8 (8.11.24254.15002, 2024-09-10)
- LBT-GH Version 1.8.47
- OpenStudio v3.8.0 (f953b6fcaf)
- EnergyPlus v24.1.0 (9d7789a3ac)
If anyone has any insight or suggestions, I would appreciate it. Maybe its a versions issue? Maybe its a MacOS thing?
Thanks!
@edpmay
