With the SolveAdjacencies HB component, is it possible to specify new EP constructions for more than one surface type? That is: specify a wall construction and also an interior window construction. This seems like a syntax question. I took a look at the ventilated DSF example, and searched for other “solve” situations in Hydra, but haven’t found any examples showing multiple constructions yet.
In the meantime, I can use the SetEPZoneIntConstr to re-define the surfaces after the surface mating. But any suggestions welcome!
