Hello everyone,
I am studying the effects of a possible heat island due to installing solar panels and was wondering if I could somewhere input the temperature manually. I was running on energyplus for a comfort map, but since I have measurements it would be more precise if I could do that and then see how it could spread through air. Is it a thing? Can I do it?
With the example of the microclamte map (see link below) you can input surface temeratures.
These are just lists of 8760 values with a ladybug header. When you know the order and the names of the surfaces involved you can override these values with your own values.
