Terrain Mask
Hi there!
We are working on a university project about lighting design and daylighting evaluation for an office building located in Trento (Italy).
We are currently performing a daylight analysis and calculating the daylight factor and everything works when we consider only the geometry of the building itself.
One of the tasks that we want to furhter implement is the insertion of the surrounding environment (the office is located near a mountain area).
We modeled the mountain using the geo-location function of Sketchup, imported the geometry into Rhino and created the surface.
Then we added the mountain to grasshopper throug a brep, but then it is no longer able to run the simulation.
Isn’t Grasshopper able to handle such complex surfaces? Or are we doing something wrong?
You can find the gh file we used attached to this message.
Thank you in advance!
prj_prova.gh (681 KB)
Can’t check your file right now, but i suggest trying the recent Djordje’s addition: terrainShadingMask.
Search for it in the group. I’m sure you’ll find it useful.
Thanks! I try it
Update: the terrain Shading Mask component was very helpful and I managed to create it.
How can I then couple the shading mask with the sky component to let it influence the illuminance analysis?
Thanks
Still, without seeing the file, i was thinking about the terrainShadingMask to be used as context. In this way it will block the direct sun. If you are interested in the indirect/diffuse i recommend to build basic surface that represent the site conditions.
Makes sense?
Abraham,
thanks for your answers.
It would be enough for me to use the mask to block the direct radiation. I already tried to connect it to the geometry (image below) but it does not work. Is there something missing?
I suppose you need to pass the geometries through the HB_Surface component to make them recognizable by HB (I mean ALL your geometries: ground, terrain and of course the room).
From your image i’m not sure you are doing that.
Ok, there was one HBsurface missing. Now the simulation runs.
However the illuminance analysis shows exactly the same results, with or without the shading mask, even when the sun is very low.
Maybe the mask is placed too far from my geometry to show noticeable results.
I’m wondering how does it decide where to place the mask (given that I put no input data as context_ in the TerrainShadingMask element).
Is it actually placed in such a way to give the same shading effect as the real terrain geometry?
Thanks for the answers!
About the location (radius of the mask) see my questions and Djordje’s answers in the discussion about this component. If you don’t give any context you’ll get the same radius as the default sunpath component.
At this point, looking at the mask’s image, see the hours where the mask blocks the sun. Seems that the influence of the topography happens at late hours.
Post the updated file where the geometry is internalised (specially the mask’s) so people here can have a better look.
Here is the file.
There is still a problem while connecting the mask with the other geometries.
Thanks.
prj_prova_internalized.gh (1.03 MB)
I don’t know what is the problem you mentioned. It runs fine in my system.
Anyway, i added a sunpath (independent) and set the hour where i see the sun is blocked by the mask.
I tested with and without the topography and i can’t say the results are substantially different. Though there are differences (small ones). So the mask is affecting the simulation results. It happens that it is low or it is far away from your site.
prj_prova_internalized_AY.gh (1.07 MB)
The fact is that I expected the influence of the mask to be greater.
I run the analysis with a finer grid when the sun should be covered by the mask. The results with and without the mask are below (the only noticeable difference is the Daylight Factor).
Actually I tried also to create the mask of the mountain using the topography I imported from Sketchup and the Ladybug Shading Mask II component. In this way the shading effect is well noticeable, but the process of creating the mask from such a complex geometry is very slow.
I was just curios to see this terrain shading mask working because, for future projects, it would be easier and faster to use.
Thanks!
Theoretically the maskTopography and the ShadingmaskII should be similar (the mask) and as such their influence.
I’m not sure if your case is influenced by the geometry of the room and it’s orientation and window locations, rather than the mask itself.
I would try a basic case (one room, one window) that you can check parametrically (orientation, window size, etc) in order to understand better the mask influence.
@ Abraham: thank you for pointing to the component!
@ Giacomo,
If it is not working, then this can be a limitation of Honeybee, not the Terrain shading mask component.
You can authenticate the mask shape by using the Udeuschle panorama generator (I used the following Trento coordinates: lat:46.066667, long:11.116667):
Sketchup has a similar plugin for Trynsys3D terrain shading masks.
I gave a reply on your upper questions in here, in component’s release topic, so that it would be useful for others users too.
I can make a component which will automatically generate the topography of the local terrain, for a given latitude/longitude, but you will have to wait some time. I am currently doing some repairing around my house and cottage, and I do not have any spare time.
Have in mind that depending on the configuration of you PC, you may not be able to have the terrain radius of up to 100 km. While Terrain Shading Mask component actually creates this terrain, it does not add it to the grasshopper document. In your case the terrain will be added to the grasshopper document which may crash Rhino depending on your PC configuration (for example it crashes Rhino on my PC).
