I want to know the EP output variables used to calculate the output on the Read EP Results and Read EP Surface Results components.
May I ask if the following list is correct?
May I also ask what the EP output variables are to calculate outdoorAirEnergy?
Thank you very much!
Output variables on the Read EP Results component:
[1] totalThermalEnergy
cooling
heating
[2] thermalEnergyBalance
cooling (-)
and
heating (+)
[3] cooling
Zone Ideal Loads Supply Air Total Cooling Energy J
Zone Ideal Loads Supply Air Sensible Cooling Energy J
Zone Ideal Loads Supply Air Latent Cooling Energy J
[4] heating
Zone Ideal Loads Supply Air Total Heating Energy J
Zone Ideal Loads Supply Air Sensible Heating Energy J
Zone Ideal Loads Supply Air Latent Heating Energy J
[5] electricLight
Zone Lights Electric Energy J
[6] electricEquip
Electric Equipment Electric Energy J
[7] peopleGains
Zone People Total Heating Energy J
[8] totalSolarGain
Zone Windows Total Transmitted Solar Radiation Energy
[9] infiltrationEnergy
Zone Infiltration Total Heat Gain Energy (+)
and
Zone Infiltration Total Heat Loss Energy (-)
[10] outdoorAirEnergy
[11] natVentEnergy
Zone Ventilation Total Heat Gain Energy (+)
and
Zone Ventilation Total Heat Loss Energy (-)
[12] operativeTemperature
Zone Operative Temperature
[13] airTemperature
Zone Mean Air Temperature
[14] meanRadTemperature
Zone Mean Radiant Temperature
[15] relativeHumidity
Zone Air Relative Humidity
[16] airFlowVolume
[infiltrationFlow] Zone Infiltration Standard Density Volume Flow Rate
[natVentFlow] Zone Ventilation Standard Density Volume Flow Rate
[mechSysAirFlow] Zone Mechanical Ventilation Standard Density Volume Flow Rate
[earthTubeFlow] Earth Tube Air Flow Volume
[17] airHeatGainRate
[surfaceAirGain] Zone Air Heat Balance Surface Convection Rate
[systemAirGain] Zone Air Heat Balance System Air Transfer Rate
Output variables on the Read EP Surface Results component:
[1] surfaceIndoorTemp
Surface Inside Face Temperature
[2] surfaceOutdoorTemp
Surface Outside Face Temperature
[3] surfaceEnergyFlow
[opaqueEnergyFlow] Surface Average Face Conduction Heat Transfer Energy
[glazEnergyFlow] Surface Window Heat Gain Energy
[4] opaqueEnergyFlow
[5] glazEnergyFlow
[6] windowTotalSolarEnergy
Surface Window Transmitted Solar Radiation Energy
[7] windowBeamEnergy
Surface Window Transmitted Beam Solar Radiation Energy
[8] windowDiffEnergy
Surface Window Transmitted Diffuse Solar Radiation Energy
[9] windowTransmissivity
Surface Window System Solar Transmittance
