I updated LBT from 1.3. to 1.4.
In addition, I updated Openstudio and Radiance to the latest version.
When I run a simulation with the gh file which does work well before I uploaded, “HB model to OSM” say an error “1. Solution exception:Failed to run OpenStudio CLI”.
You would usually get a more detailed message about what specifically went wrong with OpenStudio for this case. So the fact that you aren’t getting anything indicates that something bigger went wrong. Could you upload a Grasshopper file that recreates the issue?
Your file has too many external dependencies in it and too much going on for me to be able to recreate the issue on my end. But I see that you are using a custom Measure (and a massive one at that, which it looks like you did not write). Generally speaking, measures can easily cause OpenStudio CLI fail if you don’t use them correctly.
The measure is one dependency that I don’t have on my system. There were also a a few other Grasshopper plugins being used in the definition that I don’t have installed.
