Hello, I am researching the effect of shading in greenhouses through simulation.
Here, I have one question.
I’m curious about the priorities of dynamic shade and hb rotate.
After designing the shading using dynamic shades, i want to change the orientation of the greenhouse using HB rotate.
(Same as picture above)
The selected part in the picture above is the shade I designed.
At this time, if I use HB retate, will the orientation of the dynamic shade also change?
Or does the dynamic shade not change?
If it doesn’t change, I’ll have to rewrite the logic.
Thanks
