I ran the annual daylight simulation and created the illuminance graph for the 21st of September with one test point in the centre of the zone:
Then, I used the ‘read annual result’ component to define the lighting control group with control type ‘4’, auto-dimming. I set the occupancy profile from 9am-5pm with lighting setpoint&thresholds 300lux. Considering this, the illuminance from daylight is not enough between 9am-3pm, so the electric light must be switched on automatically. However, the graph plotted showed the electric switch is OFF.
Do you know what else I must assign to get the lighting control recipe to work?
Berrak
