Hello, I have a problem with running energy simulation:
- The simulation has failed because of this fatal error: ** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
Full text of errors:
Current document units is in Meters
Conversion to Meters will be applied = 1.000
[1 of 8] Writing simulation parameters…
Can’t find ddy file next to the EPW.
Extreme values from the weather file design will be used instead.
[2 of 8] No context surfaces…
[3 of 8] Writing geometry…
One of the surfaces has less than 3 identical coordinates and is removed.
[4 of 8] Writing Electric Load Center - Generator specifications …
[5 of 8] Writing materials and constructions…
[6 of 8] Writing schedules…
[7 of 8] Writing loads and ideal air system…
[8 of 8] Writing outputs…
… idf file is successfully written to : C:\Ladybug\OnlineCoursess\EnergyPlus\OnlineCoursess.idf
Analysis is running!..
Done! Read below for errors and warnings:
Program Version,EnergyPlus, Version 9.6.0-4b123cf80f, YMD=2022.05.11 16:23,
** Severe ** [BuildingSurface:Detailed][84267334389c4848b1a6][sun_exposure] - “WindExposed” - Failed to match against any enum values.
** Severe ** [BuildingSurface:Detailed][84267334389c4848b1a6][vertices][3] - Missing required property ‘vertex_z_coordinate’.
** Warning ** Version: in IDF="=9.3.0" not the same as expected=“9.6”
…Summary of Errors that led to program termination:
… Reference severe error count=2
… Last severe error=[BuildingSurface:Detailed][84267334389c4848b1a6][vertices][3] - Missing required property ‘vertex_z_coordinate’.
************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
************* EnergyPlus Terminated–Fatal Error Detected. 1 Warning; 2 Severe Errors; Elapsed Time=00hr 00min 0.16sec
I really need your help
