Some floors on the first floor is set as exposed floor i guess because i set multiple Breps but i did that to give different zone programs according to function, is there another way to fix that.
Also runEnergySimulation didn’t work giving that error:
Solution exception:‘hb_EPFenSurface’ object has no attribute ‘shadeMaterial’
Updating versions will also fix the duplicate names issue in cases of unassigned names. I added in some code a few months ago that gives better names to the zones by default.
Thanks Mostapha and Chris, ya i updated the versions but still some errors still coming up like.
The simulation has not run correctly because of this severe error:
** Severe ** Problem in interior solar distribution calculation (CHKBKS)
Regarding the zone names i had to change it manually by typing in into a panel.
One more thing i ran annual energy simulation than linked the cooling and other outputs to ladybug 3d chart but only 6 or 4 months appeared and the rest didn’t
