THERM and Honeybee Environment
I’ve started the “Envelope Design with THERM” course on ladybug-tools-academy but stacked in the only beginning…
First of all, there are no sample files in the course. Please fix that.
Secondly, I’ve installed Rhino7, ladybug 1.4.0, and THERM, and they seem to work, but in course videos, there are much more Icons in Grasshopper than I have.
In the First lesson, he used “honeybee create therm polygon.”
Unfortunately, I don’t have any icons related to the THERM.
THERM simulation needs ladybug legacy version 0.069, not ladybug 1.4.0.
You can down ladybug legacy version 0.069 from food4rhino.
@minggangyin is right.
The THERM components are only for the Legacy plugin at the moment. We are just starting to make official video tutorials for the LBT plugin and it will be some time before we have any type of THERM functionality in the LBT plugin.
Also, here are the sample files for that video series with the Legacy THERM components:
https://hydrashare.github.io/hydra/?keywords=LBNL
Hi, Does THERM work with Rhino 7? I am having issues and wondering if this is the problem
the THERM plugin will not work in R7 but it will work in R6
Hi again, thank you Trevor, I finally got everything to work!
I have another question unfortunately, hopefully someone can help me out…
I am an architect with no environmental background (so be gentle).
Is there a way to know in THERM how much time it takes the heat to go inside the house?
Meaning, I am working with rammed earth blocks and I want to be able to control the heat transfer- release the heat after 12 hours, depending on the walls orientation (radiation value) and surface area.
I will attach what I have so far after going through all the subscribed tutorials.
Thank you
THERM WORFLOW-clean.gh (779.8 KB)
THERM WORKFLOW-clean.3dm (227.0 KB)
@ella THERM is not a dynamic solver, its primarily a steady-state 2d heat transfer analysis tool but it does not perform dynamic ( time-dependent) simulations like you described above.
Ho no… Thank you Trevor for letting me know! Do you have any recommendation of programs that can do that? Its really outside of my ballpark :frowning:
Hello there, so there are no (at the moment) way to use Ladybug 1.9 for wall assembly simulation ?
@Alakelele The move here is to install the legacy plugin and use the old school therm tools you should use it on rhino 6 I believe, there are not new 1.9 THERM tools
Best
-Trevor
No new tool so far, the Ladybug team has been very responsive to suggestions.
Hey @Alakelele ,
I already mentioned this to @TrevorFedyna but I am working on a new proof of concept for an updated connection to THERM now that we can eventually ship with the latest LBT plugin.
We will be using therm 8 here on out, which generally solves a lot of headaches for us. Also, therm 8 has a (beta) transient simulation capability. So that should start to address some of the other questions brought up on this thread.
Super !
This a great news !
How much better is the new 8th version ?
I am with you a 100% on this one, Therm modeling UX is probably not the best, Rhino would be a huge plus !
This issue is now finally addressed by the new Fairyfly plugin that we announced here:
Ahhhhhhh, super !!!
I used the versioner and restarted Rhino twice.
Still shows up as a problem
Maybe you should just run the Pollination single-click installer, @Alakelele .
It’s working now, good job, just showing a warning
Hello !
I got a strange error
