Thermal Comfort PMV Component Error
Running into this error with the PMV Comfort Map component, although the same inputs from the Adaptive Comfort Map components work perfectly. Not even sure where to start with this, if you can help me understand the error:
  1. Solution exception:
    The recipe failed to run with the following error(s):
2023-10-23 16:55:32 ERROR: “CreateWea” failed. See below for more information:
Access is denied.
2023-10-23 16:55:38 ERROR: “CreateResultInfo” failed. See below for more information:
Access is denied.
2023-10-23 16:56:51 ERROR: “CreateResultInfo” failed. See below for more information:
Access is denied.
2023-10-23 17:01:18 ERROR: “CreateResultInfo” failed. See below for more information:
Access is denied.
Execution Summary
Scheduled 35 tasks of which:
  • 13 ran successfully:
    • 1 CopyGridInfo(…)
    • 1 CopyRedistInfo(…)
    • 1 CreateModelOccSchedules(…)
    • 1 CreateModelTransSchedules(…)
    • 1 CreateOctree(…)
  • 2 failed:
    • 1 CreateResultInfo(…)
    • 1 CreateWea(…)
  • 20 were left pending, among these:
    • 20 had failed dependencies:
      • 1 CopyResultInfo(…)
      • 1 CreateDirectSky(…)
      • 1 CreateDynamicOctrees(…)
      • 1 CreateOctreeWithSuns(…)
      • 1 CreateShadeTransOctrees(…)
Scheduled 12 tasks of which:
  • 8 complete ones were encountered:
    • 1 CopyGridInfo(…)
    • 1 RestructureConditionIntensityResults(…)
    • 1 RestructureConditionResults(…)
    • 1 RestructureCspResults(…)
  • 1 failed:
  • 3 were left pending, among these:
    • 3 had failed dependencies:
      • 1 LetPmvComfortMapFly(…)
      • 1 _Main_6b2d7cbaOrchestrator(…)
    • 1 CopyGridInfo(…)
  • 1 failed:
Hi @Elliot_Glassman ,
In the past, I have seen error logs like this when the hard drive runs out of space mid-way through the simulation. How much free space is available on the hard drive where you are running the simulation?
There is 222 GB free. We have also run into this issue on a few machines… sometimes changing the location helps
Was wondering if there was any additional thoughts on this error… still seems to be occurring. No problems with the adaptive comfort component, just the PMV one.
Actually I spoke too soon, had an issue generating the results with the adaptive comfort module as well. Similar error, noticed things like this in the window while simulating:
Hi @Elliot_Glassman, how didi you fix this error?
To be honest, I don’t know… the script seems to be working now. Maybe there was a particular issue with my model? Doing a lot more thermal comfort models these days… I will report out as I learned more about what circumstances causes the issue.
My model presented the same issue, even after I fixed the project units. I fixed diz error re-drawing my model.
