Thermal Wall Optimization
Hi!
I’m having a bit of trouble figuring out the right approach for something…
I’d like to model a wall which has pipes embedded in the walls acting as heat exchangers throughout the day. I’d like to optimize the size of pipe, number of pipes, location etc etc using software like Therm which outputes a heat map.
Thing is, I’m having difficulty linking this up to Galapagos/Octopus since each run of analysis requires you to open up Therm Seperately, run an analysis and re-import it into GH.
… Any Suggestions how to go about this? Is there a way to perform the analysis entire through grasshopper so it can be easily linked to Galapagos etc.?
thanks!
Hi Chris,
Excellent question. We have historically not been able to run THERM directly from Grasshopper because the Command Line Interface (CLI) version of THERM has not been free. However, the wonderful scientists at LBNL have changed this policy with the release of THERM 7.5 and it seems they are gradually working towards an eventual open source version of the software.
I have had the implementation of the THERM CLI in Honeybee on my agenda for a few months now and you have given me a good reason to get it done. I will try to implement this soon and I will post back here once it is ready. Once this is in place, you will be able to parametrically generate THERM files and automatically run them through THERM to get the results.
-Chris
Hi! Oh that
Chris,
I am not sure what your response is referring to. Was my response clear and could you elaborate?
I wonder is there a standard way to draw this for a Therm study, to include the pipes covering different areas of the wall?
hi! sorry really did not notice this reply until now!
I had send this reply via my mobile - apparently it didn’t send properly. The gist was that it would be a great idea to implement THERM in honeybee because referencing and importing 100 results into grasshopper was becoming a pain. The screenshot was showing
Chris BC,
I just finished implementing THERM Command Line Interface so that you can now run THERM simulations directly from Grasshopper without the need to open files in the THERM interface. Now, the running of 100 THERM models should be much easier. I updated the example file here to show how to do it:
Cheers,
-Chris
This is great Chris!!
