Hi
I am trying to simulate thermochromic colors on the building facade. My intended thermochromic color changes its color and furtherly its related physical properties (thermal, solar, and visible absorptance) around 28degree( C ) so I need a control procedure that checks external surfaces temperature at the start of any timestep during the run process and modifies those physical properties based on the current exterior surface temperature.
Is there any way to operate such instruction through the honeybee framework?
