Title: Honeybee Energy Simulation – Room Duplication, Cooling Results and Construction Verification
BATAM_REMODEL_1.3dm (351.6 KB)
BATAM_REMODEL_1.gh (279.7 KB)
Hello Ladybug Tools Community,
I am working on a room-wise cooling energy simulation using Rhino, Grasshopper, Honeybee and OpenStudio.
My workflow:
  1. Created five separate HB Room components, each receiving six Geometry faces directly.
  2. Connected them to HB Solve Adjacency and HB Model.
  3. Converted the model using HB Model to OSM.
  4. Ran the EnergyPlus simulation.
  5. Extracted cooling energy using HB Read Room Energy Result.
  6. Visualised the results using LB Hourly Plot Chart.
I am facing three issues:
  1. Duplicate Rooms: Although I have created five physical rooms, the final HB Model contains 15 Room objects, with three entries for each room name. Consequently, I get three heatmaps per room instead of one. How can I identify and resolve the duplication?
  2. Zero Cooling Values: The exported CSV contains zero cooling energy values during certain hours. Is this expected behaviour or could there be an issue with the simulation or reporting?
  3. Construction Assignment Verification: I have assigned different materials and constructions to individual faces of each room (walls, floors, roofs and windows). However, I am unsure whether these assignments are actually being transferred to the OpenStudio/EnergyPlus model and considered in the simulation. How can I verify this?
My expected outcome:
  • Five physical rooms represented by five Honeybee Room objects.
  • One cooling energy heatmap per room.
  • Reliable hourly cooling energy results.
  • Correct consideration of individually assigned face constructions in EnergyPlus.
I would appreciate guidance on identifying the causes and resolving these issues.
Thank you. @chris @mostapha @AbrahamYezioro @Erikbeeren
