hello friends
Does anyone have a solution for modeling material such as a translucent plant wall for Radinace?
Supposedly, it is possible to use ready-made Rhino objects (exactly the geometry of the plant) and give it an opaque material?
hello friends
Yes you can use Rhino made model by assigning it to the Grasshopper and use the below-shown Honeybee component to set translucent properties for the plant wall.
thanks @Naga
Of course, I did not mean that.
I want to extract the material from the actual specifications. Also change the density of branches and leaves based on openness factor.
