The component asks me for “transmittance” values bettween 0-1. Where can I get those?
Maybe I’m having a translation problem. I’m spanish, and in other articles, i’ve read that the U values are refered to “transmitancia térmica”. What is “transmittance” refered to in “HB_Glass modifier”?
I think there are two issues here, first a partial translation issue, and second confusion of purpose of Radiance.
1. Translation Correction
"Transmitancia térmica” translates to “thermal transmittance”, which you are correct, is what the U-value represents. This is not what the “transmittance” refers to in the HB Glass Modifier
component. That “transmittance” refers to the fraction of light transmitted through the material (with the remaining fraction of light absorbed and reflected from the material). You can’t convert “thermal transmittance” to light transmittance.
2. Radiance Purpose Correction
The HB Glass Modifier
component specifies materials for a Radiance simulation with HB-Radiance. Radiance simulations are lighting simulations only, they do not model thermal energy transfer. Therefore, there is no U-value or "transmitancia térmica” input for Radiance. You can however use the U-values in an EnergyPlus simulation with HB-Energy, which does model thermal energy transfer.
Hopefully that all makes sense. From this point you have two choices: if you are only interested in an accurate model of the physical/optical transmission of solar radiation, you can use HB-Radiance. I think the simplest way to do this is simply search for lighting or solar-specific material specifications. The manafacturer should have this information somewhere. On the other hand, if you want to capture thermal energy effects (like the way solar radiation is driven partially by the evolving temperature differences in your assembly and interior), and are okay with using a simplified model of physical/optical radiation transmission, you can use HB-Energy, and simply use the U-values, and solar g values specified in your chart.
