Im a bit confused as to whether I can only use this on a single tree basis. I think I may be stressing my machine to the limit and it just will not compute. I’ve let it run for multiple hours. Any insights would be wonderful.
If you can provide your GH script it will be easier for people to take a look and help.
I am guessing that you are assessing the impact of multiple trees following Chris’s example. If the geometry representing the trees is simple enough (most of the time flat surfaces will do) it should not put much stress on the simulation. I am not sure what happens with more complex shapes and the view factor calculations. You can try starting with a very coarse grid and move to more refined studies perhaps.
The link I provided in my previous reply is not the link to the starting reply of the topic. But a permalink (link to an individual topic reply). This one:
