I’m trying to create a glass house with glass internal walls with different spacing between the glass to test the effects on the indoor. but once plugging it in i keep getting an error like this:
{0;0}
0. Current document units is in Meters
- Conversion to Meters will be applied = 1.000
- Current working directory is set to: C:\Users\PES-Architects\AppData\Roaming\Ladybug\unnamed\OpenStudio
- Runtime error (IndexOutOfRangeException): index out of range: 0
- Traceback:
line 5843, in checkChildSurfaces, “”
line 5971, in checkZoneSurface, “”
line 5657, in evaluateZones, “”
line 5430, in main, “”
line 5649, in script
below is the link to the grasshopper file. sorry couldn’t attached because i’m a new user.
grasshopper file
thank you so much for the help in advance.
