I am trying to run daylight simulation using “runDaylightAnalysis” component. I have connected epw file to “daylightFactorSimulation” component and ended up getting an error (refer to below figure). I am attaching the grasshopper file as well for reference.
Hi, @Rinku.David The input of unformsky should be true or false, not sky file. If you want to calculate the lux , you should use gridbase simulation instead of daylightfactor simulation.
Hi @Rinku.David,
As @minggangyin suggested, you only need to provide the either “True” or “False” value at the uniformSky_ input on the daylightFactorSimulation component.
Since this simulation uses either uniform or cloudy sky, you don’t need to set a date for simulation.
Following are images of uniform sky and the overcast sky. As you can see they are rotational invariant.
