UDI Heat map LBT 1.3.0
Hello everyone!
I am working on UDI and I connect the values to a heat map component, I get a map as follows:
UDI
Are the colors of the heat map correct? the points away from the aperture have the highest values! Am I getting the concept of UDI wrong?
This is my script.
UDI.gh (162.7 KB)
Hey @Ahd,
The lower UDI near the aperture is likely due to the upper UDI threshold being exceeded.
This website has a good explanation - note I think the ladybug tools default is an upper threshold of 3000lux
https://patternguide.advancedbuildings.net/using-this-guide/analysis-methods/useful-daylight-illuminance.html
Got it, I will see the website
Thank you :slight_smile:
