I have ladybug, pollination, and Openstudio downloaded. In order to work in PHIUS WUFI i need gbxml geometry. honeybee will not let me export through DumpGBXML. the errors refer to openstudio but do not clear up when i reinstall it.
Exporting pollination geometry directly to gbxml thought export selected crashed my Rhino
Hi @wmolloy,
This has to do with your input file. I would use the validate model component to see if the model is valid. If that’s the case, and it is still failing, share the model with us and we should be able to help you.
