Unable to use the Honeybee_Indoor View Factor Calculator
There is an issue of running the Honeybee_Indoor View Factor Calculator Component. Cannot get any result from the component of Viewfactormesh.
Thanks for your help!
Tan_Atrium Study.gh (719 KB)
Shengji,
There are no floor surfaces within your energy model:
Therefore, plugging in a number to distFromFloorOrSrf_ or using the default number will produce no test points at which to evaluate comfort. I would suggest either building your energy model with floor surfaces or, if there truly are no floors, plug in a Brep into the distFromFloorOrSrf_ input on the View Factor component.
-Chris
Hi Chris,
Thank you so much for your reply. It works so I can create prototypes of atrium showing the performance of visual comfort and thermal comfort. Again, I appreciate your help and your lecture in Penn designwas amazing!
