So, I am working on Rhino 7. I have Ladybug 0.0.69 and Honeybee 0.0.66 Legacy version.
I tried using the 3D Isovist command. The component is not showing any error. And it shows ladybug is running. However, I am still unable to view the output on my Rhino 7.
Same script run on Rhino 6 gives the result.
What could be the possible problem.
Has anyone faced this issue? What’s the solution?
