Understanding roles of glazing in HB Peak Loads component
I am trying to figure out what is behind the Window Conduction when plotting HB Peak Loads.
Looking at a shoebox with given glazing ratio, I get presented with this peak load chart which I am not sure I fully understand.
One would think that, were this the result of conduction heat gains (or losses), this would reduce with an improvement in Uvalues. However, changing Uvalues has a negligible impact on this.
Given I am testing this for London, UK, where temperature difference between indoor and outdoor temps would be minor for the Uvalues to make a real difference, I was tempted to assume this Window Conduction gain would indicate a ‘secondary’ solar gain gain, i.e. the absorbed solar radiation that would be re-emitted into the indoor thermal zone.
I tested a south and a south-west orientations, and in both cases the amount of Window Conduction appears excessive, when compared to Solar, which would contradict my hypothesis of this being secondary (re-emitted) solar heat gains.
Any idea of what this may be? What eplus variables is this plotting?
Actually, having though about it, it seems reasonable for the figures to actually represent heat gains / losses purely as a result of Delta T. Having assumed every other boundary construction as adiabatic, all heat losses would happen through the opaque and glazed constructions of the facade.
Having asked ChatGPT to perform a quick calc to double check that, its response is quite straightforward:
