Unrecognized Object: ImageFromPath RCDVisualise - Plugin not found
Hi
when I’m opening the honeybee example files, I get the message, that the above file couldn’t be loaded.
I’ve googled for it, but couldn’t find anything about this on the net.
What does this means?
-rpict
I would say that you are missing installing EmbryoViz, the link is in the file you are opening (right side).
Hi A
I experienced the same problem and i don’t understand what you said “the link is in the file you are opening”, Could you explain more? How can i fix this problem? Sorry, i am new in Ladybug.Thanks.
Open the example file 005_glareAnalysis and in the right side of the file you can see where you can download the plugin.
