I was trying to update the components used in a GH file using the latest update Ladybug component, and it gave the warning: 1. Solution exception:File is not a zip file
May I ask what might the source of this issue?
Thanks!
Thanks!
Grasshope,
You can get that error if your internet connection is bad and the component fails to download the most recent components from the github. When you try again with a better internet connction, it should work.
Also, you are correct that the component does not update itself. You can imagine that it is difficult for a script to replace itself while it is running. Thankfully, we don’t really make changes to these udpate components (it’s really only to change the date to be the last release).
-Chris
noted with thanks, Chris!
I’ll try the update components later!
