Thanks for reporting this. Can you print date on the line before this line and see how it looks like. Chris and I used the component yo update all the Hydra examples and it worked with no issues.
As i said it used to work, months ago, and at some point it stopped. I suspect it was related with uninstalling Python 3.x becouse of problems with the envi-met plugin. There were some instructions how to deal with Ironpython install by (forgot his name) Piacentino.
Also, the datetime doesn’t have the strptime but has a strftime function. But it doesn’t work either.
Hi Abraham, Thanks for checking. Can you try the attached component and share the full error message? Python 3 should not affect IronPython installation.
