Upgrade to Pydantic >2.0
Hi @Chris, @mostapha, all,
I wanted to file a request that the team consider upgrading the Pydantic dependency to >2
Currently the pydantic-openapi-helper library requires pydantic<2
This causes some ‘friction’ and conflicts with other packages. It also causes some issues with LLM usage, as most default to Pydantic>2 syntax these days (in my experience at least). So far we have been able to find work-arounds, though sometimes that means forgoing the use of certain tools/packages/extensions.
I know it is a pain, since they changed the api when they went from v1 to v2, but I’d like to request that eventually this dependency get upgraded in order to help facilitate the use of the LBT packages more easily within other environments.
Pydantic 2 has been out for almost 2 years now, so would be be much appreciated if we could align the LBT dependencies with the modern version at some point.
thanks!!
@edpmay
Hey @edpmay ,
This is more of a question for @mostapha since he did a lot of the work to put together the pydantic-openapi-helper and he has the best sense of how large an effort it is to make the change. But, just to set expectations, I am pretty sure that it’s a substantial effort and this is the first time that I have seen anyone bring up the pydantic 2.0 shift as a pain point in the LBT community. So it still might be some time before the cost/benefit to making the change becomes worth it.
Can you be more specific about the packages that are causing the dependency conflicts? Maybe we can find a solution to help you resolve or work around them for the time being until we can eventually update the LBT core libraries.
Hi @mostapha, @chris, all.
Resurrecting this thread as I sometimes find myself checking back here in case anything else has been added to it :smiley:
It’s been a while since the original reply, and I’m starting to experience a lot of other packages moving over to pydantic>2, which means trying to use LB packages in environments that include them is getting trickier.
Has any more thought been given to upgrading the version used by the wider LB tools?
Hello everyone,
This is one of those items that will be very challenging to predict without some testing. Generally speaking, it is a major effort since it will affect both Ladybug Tools and Pollination libraries. This might be a good case to test some of the AI coding agents and see if they could save us some time. It is unlikely that we get to work on this before October.
We might be able to get around this for Ladybug Tools by removing pydantic-openapi-helper from the required dependencies. It is mainly used to generate the files that are needed to generate the .NET version of the schemas. I don’t know if we need it as a required dependency.
hi,@mostapha
I encountered this dependency conflict while attempting to develop some MCP Server tools.
Currently, the vast majority of LLM tools have begun adopting Pydantic 2.x as their primary dependency. For instance, with FastMCP, I experienced severe conflicts when trying to use modules related to ladybug_vtk, preventing me from developing any functionality using those modules.
Hi @ZhengrongTao, noted. Let me see what I can do. It might still take me some time to make the move but this is now becoming an urgent task to unblock you.
hi,@mostapha
Thank you for your prompt reply.
Mingbo told me ,there are many aspects that might be affected by this,I am willing to wait.You can handle the matters that you consider to be of the highest priority first.
I am currently evaluating other functions that can avoid the dependency on Pydantic version, currently most of the editing functions have been able to be incorporated into MCP.
bset.
Zhengrong
Thank you for your understanding, @ZhengrongTao. The last thing I want to do is slow down innovation but as you mentioned this one is not an easy change, otherwise, I would have done it already.
Hi @edpmay and @ZhengrongTao,
Thanks to @mikkel’s work the Ladybug Tools core libraries are now using Pydantic v2. Hopefully, that will unblock both of you for your work.
hi,@mostapha
Thank you to the LBT team for your work… It’s really great.
bset.
Zhengrong
