UrbanOpt_ Dragonfly
Hi @Asisnath ,
Thanks for the words of support for the new plugin.
NREL has released an executable installer for URBANopt, which makes the process 100 times easier than before. All you should have to do is run that executable installer and dragonfly should work with it out of the box.
FYI, you’ll see in the release notes that URBANopt supports parallel simulation of buildings (without district systems) at the moment.
