URBANOpt HVAC is not working after version up to 1.4.3
Hi everyone,
I am using URBANOpt with dragonfly and encountered weird situation.
The thing is that I cannot model the HVAC system after update using LB versioner.
I think it is so wiered because the energy usage is totally gone for heating and cooling so the overall energy demand tends to be really low.
I am wondering this issue is only for the specific types of HVAC but the thing is that I really need the type of HVAC I am using now.
Please someone review the file and let me know how it goes!! Thanks!!!
from_building_footprints_junoh.gh (122.0 KB)
Sorry for the late response, @Junoh . I will have a look later today. It looks like you are assigning the HVAC correctly.
Are you sure that you are setting _conditioned_ to True when you first create the Dragonfly Buildings (or Room2Ds)?
Also, what version of URBANopt are you using?
I did set conditioned to True and the version is URBANoptCLI_0.7.1.
Thanks for reply!!
Hey @Junoh ,
This was the result of a bug that was accidentally introduced 4 days ago into the latest development version of the plugin but I just pushed half of a fix for it yesterday and I just pushed the rest of the fix right now. So, if you run the LB Versioner again in ~30 minutes, you’ll be able to simulate your model without issues.
The bug only affected the Heating/Cooling HVAC templates and none of the other HVAC templates were affected.
Thanks for reporting the bug, @Junoh .
Hi @chris ,
Thank you so much for solving this issue!! I’ll run the LB versioner again!!
