URBANopt in Dragonfly
1. Solution exception:The URBANopt simulation failed to run.
No results were found at:
C:\Users\mimit\simulation\CU_Boulder\run\honeybee_scenario
Top level ::CompositeIO is deprecated, require 'multipart/post' and use `Multipart::Post::CompositeReadIO` instead!
Top level ::Parts is deprecated, require 'multipart/post' and use `Multipart::Post::Parts` instead!
C:/URBANopt-cli-0.10.0/gems/ruby/2.7.0/gems/urbanopt-cli-0.10.0/lib/uo_cli.rb:25: warning: already initialized constant URBANopt::CLI::UrbanOptCLI::COMMAND_MAP
C:/URBANopt-cli-0.10.0/gems/ruby/2.7.0/gems/urbanopt-cli-0.10.0/lib/uo_cli.rb:25: warning: previous definition of COMMAND_MAP was here
Invalid command, please run uo --help for a list of available commands
I don’t know the reason that this simulation is failing but you should probably try the latest version of the plugin (1.7.0), and see if that resolves the problem.
I have the same confusion, By updating LTB to 7.0, still cannot solve this. The simulation freeze like this.
