URBANopt Retrofiting Scenarios in Dragonfly
I’m working on a Dragonfly simulation and trying to handle multiple retrofitting scenarios for each building. Currently, I’m creating a separate project for the retrofitting scenarios with the new parameters. However, I was wondering if there’s a way to use the original Dragonfly simulation as the baseline and add the retrofitting scenarios as UrbanOpt measures.
This approach could help me avoid creating a new project from scratch, along with all the associated files and simulations.
Is it possible to run an UrbanOpt-Dragonfly project without rebuilding everything? If so, how can I modify or introduce the retrofitting properties—whether through measures or directly with code?
Thank you so much for your help!
Hi @Batiste
You can do that, but there is a better solution to apply parametric studies. Colibri is useful for this purpose. URBANopy measures are nice but are a bit complicated, you need to know how Ruby measures work properly.
You could search Colibri in this forum, there are some good tickets and chats for that.
Hope this help
