Continuing the discussion from URBANopt WindowsError due to System Language Settings:
Hi Chris,
I’m working on the sample file “from_building_solids”. I came across the same problem as Aliarch did (WindowsError), and I changed my local system setting to United States, it still shows the same error. As I open up the “uo_config_test.gh” Grasshooper definition, all I got is the following horrible thing…
I have installed UrbanOpt-cli-0.6.2 in default folder (C disk), and other components are all fit in the compatibility matrix. Could you please look at it?
One other strange thing is that if working on “from_building_footprint”, the simulation seems to run fine.
