How can I use an HDR image generated by ClimateStudio for calculating DGP with “HB-Glare Analysis”?
Does the image always have to be generated by the HB-Daylight simulation components?
This is the CS workflow template for radiance rendering:
The glare component reads the Radiance header of the HDR image, which might be the reason why it fails. I don’t what the header looks like in ClimateStudio, so you would have to share the HDR image.
sure, files are attached,
when I use the hdr extension in CS to generate one, it shows the file as an hdr in the folder but now its extension is png
I’m confused! CSdgp.gh (610.6 KB)
