Hi there!
I’m pretty excited about the Butterfly beta release… as always, thanks a lot to all contributors for the amazing work!
Now I’ve got a question: Is it possible to use it with a regular, non-docker installation of OpenFOAM?
I have, for example a Linux machine with different OF versions plus Virtualbox with a Windows 10 Guest system on it. Is it somehow possible to let Butterfly use the OF installation of the host system? (Installing OF for Windows is not possible with Virtualbox)
Or can I even set up a case on my Windows Laptop and use the seperate Linux machine (or maybe even an Amazon EC2 instance) to run the OF calculations?
If not, is it planned?
Cheers
Hi Albert,
Thanks for testing Butterfly. It is indeed quite possible, and actually very efficient, to set up the case in Butterfly and run it in Linux. OF running in Linux is, at this moment, at least 50% faster than Windows. Of course that is to be expected with a Docker installation.
Essentially, what BF will do is to help you run through the case preparation phase which is usually very time consuming. You can also use the write option in the run component to save the case and its files before you go to Linux.
Hope this helps! Please don’t hesitate to add these issues in GitHub as well, or any other issue you might find.
Kind regards,
Theodore.
Hey Theodore,
thanks for the reply, but what I actually meant is, if I can use it that way but within grasshopper like in the tutorials. Not just for preparation of the case, but actually starting the simulation. Is it possible to tell butterfly not to use the proposed docker OF but the regular OF either of the host system or of a remote machine for running the meshing and solver commands?
Thanks
I have never tried that so I’m not sure. I’d bet it won’t work out of the box since I’m not sure how you can tell BF to look into a native Linux installation. That doesn’t mean it is impossible just possibly not doable atm. However, I think it would be quite inefficient way to run things.
My above answer was concerning this sentence
This is certainly possible with the use of BF I described above. Concerning AWS instances, I am about to find out this week hopefully when I’m going to try my first cloud OF run. Will let everyone know if I do.
Kind regards,
Theodore.
alright, so i’ll have to stick with writing the case via BF and then manually copy it to my EC2 instance and run it there.
I’ve done plenty of simulations on AWS, the cool thing about that is you can create clusters and have as much computing power as you like. That way I’ve done some complex simulations with more than a hundred cores. There are some good explanations for creating clusters and running OF on the Amazon cloud in general on this site: https://cfd.direct/cloud/aws/
Cheers
Albert
As Theodore said it’s not possible at the moment however this is definitely part of the plan down the road. All the new development for any type of analysis (daylight, energy and CFD) should be cloud-enabled. We should both provide it as a service and let users such as yours set up their own and run the analysis wherever they want.
