I’m wondering if there’s a way to iterate through custom HVAC configurations with Colibri. I created several different custom HVAC systems with Ironbug and am trying to compare the EUI for each one using the same geometry. I wasn’t able to connect the HVAC System output directly to the Colibri Iterator since it’s not a list/slider. I tried using the Item Selector to make a drop down list but it didn’t accept that either. Is there another work around or is it just not possible? Thanks!
