Using honeybee calculate room heating cooling demand and ventilation heating cooling demand
I want to make a calculation for building energy and get results of space heating/cooling demand separate with ventilation heating/cooling demand.
In AHU, supply air temperature is going to be set as 19 degrees. Should I use Idea air loads or other model. if I use other model there will be COP settings. For energy demand calculation, I don’t need to use COP.
in Honeybee EP read result, which one I can get ventilation heating and cooling energy separately?
I tried to use Fan coil units+DOAS, so I got some result in fan-electricity, but how can I separate which part is for heating coil and which part is for cooling coil.
Last question. if I set COP to one, should the heating/cooling from Honeybee EP result be building heating/cooling demand?
here is the model.FanCoilDOAS.gh (588.0 KB)
Hi, Did you find your answer to share with us?
