I am trying to use the +S2 method to generate a cumulative sky.
I can edit the _cumulativeSky.bat file to use an +s2 and rerun the .bat file. However, I am not able to regenerate the .sky.
What would be the best way to proceed? can I edit the .ghuser file to use generate the +s2 bat file? can I just run the part of .ghuser script that generates the skyfile?
Open ladybug_ladybug component and change this line. Then press F5 and close ladybug_ladybug. Until the next time that you drop the original ladybug_ladybug to the canvas, the component will generate the sky with +s2.
The link provided on Github for the paper related to this discussion no longer works. Can you verify if the attached paper in this message is that same paper please?
