Thanks for the solution, @jgbrear . I’ll also add that the “Weather Statistics and Conversion” EP program will probably work for a lot of EPWs that aren’t following the EPW schema correctly.
@molly ,
Sorry for responding to this so late but we don’t have plans to add an “Open EPW” component because you can get literally the same interface by right-clicking on a native Grasshopper “File Path” component and selecting “Select one existing file”.
