UTCI accuracy LB vs HB
I am looking into assessing UTCI as accurately as possible. How do the “LB UTCI Comfort” and “HB UTCI Comfort Map” components compare in terms of accuracy?
I found a post where a comparison was made between the UTCI as calculated by “HB Outdoor Comfort Analysis Recipe” and “LB Outdoor Comfort Calculator” where they were found to be equally accurate. However, those components are no longer present in the current LB/HB version, or could it be that they were simply developed into what is now “LB UTCI Comfort” and “HB UTCI Comfort Map”?
Any help on the matter would be appreciated. Thanks!
