I’m trying to calculate UTCI for an urban area in Abu Dhabi but unfortunately, I’m in trouble with the Honeybee Zone component (as usual!). Anyone can help me with file? I’ve already checked it many times but I was not able to find the error with the closed volume.
Yes, I know. But why the HB Zones together are not a closed volume? I understand the error but no the reason why as I modeled are not representing a closed volume.
Hi @angelo.figliola !
I think the problem is that you have hole for building footprints?
If I connect your ground box then it works, but when I connect the “asphalt” I get the error because of the holes I think
I’ve done the calculation but, as you can see from the screenshot, the recipe is empty. I’m quite sure that all the steps are correct and so I’m not able to recognize where is the problem.
