UTCI Map failing on Longwave MRT step
I kept having this createLongWaveMrtMap error on the latest version using the template script with custom geometry, does it happen to anyone before?
It’s tough to know what’s up if we cannot recreate the error. Do you have a minimal sample file that recreates the problem?
Hi, @Di and @chris,
I encountered the same problem yesterday with the latest version of LBT.
When I add the transmittance schedules of the tree units and an additional schedule to the UTCI map like in the example .gh file for the time period of an extreme hot week, I get the same Runtime error.
This morning I ran the script without schedules and it worked, so I suppose it would have something to do with them.
Here is a screenshot of the schedules I used (it is still a bit unclear to me how I should integrate them with correct inputs, so that they align with each other, so I would be happy about some guidance and feedback! :slight_smile: )
Kind regards,
Lora
Hm. I still cannot recreate the error using the latest development version of the plugin and the sample file at the link you posted:
Can someone post the log file of a failing simulation that should be at:
C:\Users\[USERNAME]\simulation\sample_model_grid\pmv_comfort_map\__logs__\logs.log
That will let me know exactly what went wrong on your machines.
Hi @chris,
Please find an attached log file below:
logs.log (757.5 KB)
Thanks, @lorabo ,
I can see from the log that the main problem is a failure of the EnergyPlus simulation:
Can you try simulating your Model in OpenStudio/EnergyPlus with the HB Model to OSM component and let me know what the exact failure message is?
It appears that EnergyPlus is just crashing without warning in the log files and maybe there’s more info in the EnergyPlus .err file that gets parsed with the simulation failure of the Model to OSM component.
Thank you for the quick reply, @chris
I just ran the simulation with the HB Model to OSM component and I didn’t get any failure message with the tree transmittance schedule or the run period (for an extreme hot week; _timestep = 1).
I ran the UTCI simulation also without the UTCI schedule (screenshots below) and got the same error message like before (failed to create Long- and Shortwave MRT Map)
schedule_UTCI
Hi @lorabo ,
Can you run the “Model to OSM” component without those simulation parameters?
I think those parameters there could be interfering with me seeing the real EnergyPlus error that’s happening on your system.
If disconnecting the simulation parameters does not create the error on the “Model To OSM” component, then I can also try one other thing that could help me recreate the issue. Can you upload the idf file that the UTCI recipe produces here?
Did you ever find a solution for this? I am getting the same error but with the PMV comfort map component
  1. Solution exception:
    The recipe failed to run with the following error(s):
2025-04-10 13:44:12 ERROR: “CreateShortwaveMrtMap” failed. See below for more information:
StopIteration
Execution Summary
Scheduled 68 tasks of which:
  • 52 ran successfully:
    • 1 CalculateSphericalViewFactors(…)
    • 1 CalculateSphericalViewFactorsLoop(…)
    • 1 ComputeSphericalViewFactors(…)
    • 1 CopyGridInfo(…)
    • 1 CopyRedistInfo(…)
  • 1 failed:
    • 1 CreateShortwaveMrtMap(…)
  • 15 were left pending, among these:
    • 2 were missing external dependencies:
      • 1 RunComfortMap(…)
      • 1 RunComfortMapLoop(…)
    • 3 had failed dependencies:
      • 1 ComputeTcp(…)
      • 1 ProcessPmvMatrix(…)
      • 1 _ComfortMappingEntryPoint_73edd45fOrchestrator(…)
    • 8 had missing dependencies:
      • 1 LetPmvComfortMapFly(…)
      • 1 RestructureConditionIntensityResults(…)
      • 1 RestructureConditionResults(…)
      • 1 RestructureCspResults(…)
      • 1 RestructureHspResults(…)
    • 2 was not granted run permission by the scheduler:
It appears to be related to the analysis period. If the period is too short (less than 3 months) i get error
apartment model (1).3dm (507.4 KB)
Apartment energy (1).gh (672.4 KB)
I experienced the same issue and found that UTCI_comfort_map has problems with the run_period parameter.
The source of the problem is not completely clear, but when you feed the data with hb_analyis_period and you vary only the hours sometimes you get this fail. If I set start and end hour close to zero i get the fail even if the period end is at a later day. but not always.
I have a hunch that my weather file has no data for zero hour or the radiation is zero in it, and the simulation cannot handle when the start and end hour has no radiation, but it occurs only before dawn hours.
weather file: HUN_CTR_Tata.128360_TMYx.epw
specific time setting:
start month; day; hour - end month, day, hour - ?fail
7,15,0 - 7,16,1 - fail
7,15,0 - 7,16,0 - fail
7,15,1 - 7,16,1 - fail
7,15,1 - 7,16,0 - work
7,15,4 - 7,16,1 - work
7,15,1 - 7,16,4 - work
