Validating experimental illuminance measurements using HB Annual Daylight
Hi everyone,
I would like to cross-validate my experimental illuminance measurements with the results from the “HB Annual Daylight” recipe (or vice versa).
To achieve this, I am currently considering the following workflow:
  1. Take my measurement data (containing the columns date_st (as standard time), dni, and dhi) and interpolate/resample it into exactly 8760 rows using a custom Python function (convertTo8760).
  2. Generate a custom EPW file from this resampled dataframe using another custom function (writeEPW).
  3. Import this custom EPW into Honeybee and run the HB Annual Daylight simulation.
I have a few questions regarding this approach:
  • What do you think of this workflow? Has anyone done something similar?
  • How does HB-Radiance handle time internally? Will it correctly calculate the solar angles (zenith, azimuth) and extraterrestrial normal irradiance based on my custom timestamps (date_st) combined with the location data (lat, lon, tz, elv)? Is standard time the right one? How can seconds be handled? Or does the Annual Daylight recipe strictly assume standard hourly steps from Jan 1st 01:00 to Dec 31st 24:00, regardless of the custom timestamps provided in the EPW?
  • Do I need further columns despite ‘date_st’, ‘dni’, ‘dhi’ to successfully conduct the HB-radiance simulations such as the three-hourly surface dew point temperature within the Perez luminous efficacy models, cmp.
  • Can simulations be done without it, with the classical assumtion W=2?
  • What do you think of the demo Python code I put together (with the help of AI) to handle the 8760 conversion and EPW writing?
Thanks for your feedback and have a nice start to the week.
Simon
Here comes the code:
def writeEPW(
fnAbs: str,
df: pd.DataFrame,
lat: float,
lon: float,
tz: float,
elv: float
Writes a pandas DataFrame to a strictly compliant EnergyPlus Weather (EPW) file.
Matches the official EnergyPlus Data Dictionary (IDD).
Required columns in df: 'date_st', 'dni', 'dhi'
Optional columns (pvlib naming): 'ghi', 'temp_air', 'temp_dew', 'relative_humidity',
                                 'atmospheric_pressure', 'wind_speed', 'wind_direction', etc.
# 1. Validate mandatory columns
required_cols = ['date_st', 'dni', 'dhi']
missing_cols = [col for col in required_cols if col not in df.columns]
if missing_cols:
    raise ValueError(f"Missing required columns in DataFrame: {missing_cols}")
df_epw = df.copy()
# 2. Handle EPW Time Convention (Hours run from 1 to 24)
df_epw['date_st'] = pd.to_datetime(df_epw['date_st'])
shifted_time = df_epw['date_st'] - pd.Timedelta(hours=1)
# Checks on leap year
has_leap_day = ((shifted_time.dt.month == 2) & (shifted_time.dt.day == 29)).any()
leap_flag = "Yes" if has_leap_day else "No"
# 3. Prepare the output DataFrame with exactly 35 columns
out_df = pd.DataFrame(index=df_epw.index)
# Columns 0-4: Date and Time
out_df[0] = shifted_time.dt.year
out_df[1] = shifted_time.dt.month
out_df[2] = shifted_time.dt.day
out_df[3] = shifted_time.dt.hour + 1
out_df[4] = 60  # Minute (Standard for hourly EPW data)
# Column 5: Data Source and Uncertainty Flags
out_df[5] = "?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*0"
# 4. Define official EPW missing values based on the EnergyPlus Data Dictionary
epw_defaults = {
    6: 99.9,        # temp_air (C)
    7: 99.9,        # temp_dew (C)
    8: 999.,        # relative_humidity (%)
    9: 999999.,     # atmospheric_pressure (Pa)
    10: 9999.,      # etr (Wh/m2)
    11: 9999.,      # etrn (Wh/m2)
    12: 9999.,      # ghi_infrared (Wh/m2)
    13: 9999.,      # ghi (Wh/m2)
    14: 9999.,      # dni (Wh/m2) -> Will be overwritten
    15: 9999.,      # dhi (Wh/m2) -> Will be overwritten
    16: 999999.,    # global_hor_illum (lux)
    17: 999999.,    # direct_normal_illum (lux)
    18: 999999.,    # diffuse_horizontal_illum (lux)
    19: 9999.,      # zenith_luminance (Cd/m2)
    20: 999.,       # wind_direction (deg)
    21: 999.,       # wind_speed (m/s)
    22: 99,         # total_sky_cover (tenths) -> INT
    23: 99,         # opaque_sky_cover (tenths) -> INT
    24: 9999.,      # visibility (km)
    25: 99999.,     # ceiling_height (m)
    26: 9,          # present_weather_observation -> INT
    27: 999999999,  # present_weather_codes -> INT
    28: 999.,       # precipitable_water (mm)
    29: 0.999,      # aerosol_optical_depth (IDD specifies .999)
    30: 999,        # snow_depth (cm) -> INT
    31: 99,         # days_since_last_snowfall -> INT
    32: 999.,       # albedo
    33: 999.,       # liquid_precipitation_depth (mm)
    34: 99          # liquid_precipitation_quantity (hr) -> INT
# Fill with missing values first
for col_idx, default_val in epw_defaults.items():
    out_df[col_idx] = default_val
# 5. Overwrite defaults with actual data
col_mapping = {
    'temp_air': 6, 'temp_dew': 7, 'relative_humidity': 8,
    'atmospheric_pressure': 9, 'etr': 10, 'etrn': 11,
    'ghi_infrared': 12, 'ghi': 13, 'dni': 14, 'dhi': 15,
    'wind_direction': 20, 'wind_speed': 21, 'albedo': 32
for col_name, epw_idx in col_mapping.items():
    if col_name in df_epw.columns:
        out_df[epw_idx] = df_epw[col_name].round(3)
# 6. Enforce specific integer types required by EnergyPlus IDD
int_columns = [0, 1, 2, 3, 4, 22, 23, 26, 27, 30, 31, 34]
for c in int_columns:
    out_df[c] = out_df[c].astype(int)
# 7. Generate simplified EPW Header (incorporating dynamic leap_flag)
header_lines = [
    f"LOCATION,TestBed,-,-,Python_Script,999,{lat},{lon},{tz},{elv}\n",
    "DESIGN CONDITIONS,0\n",
    "TYPICAL/EXTREME PERIODS,0\n",
    "GROUND TEMPERATURES,0\n",
    f"HOLIDAYS/DAYLIGHT SAVINGS,{leap_flag},0,0,0\n",
    "COMMENTS 1,Generated via Python Script (IDD strictly compliant)\n",
    "COMMENTS 2,\n",
    "DATA PERIODS,1,1,Data,Sunday,1/1,12/31\n"
# 8. Create directory if it doesn't exist and write to file
dir_name = os.path.dirname(fnAbs)
if dir_name:
    os.makedirs(dir_name, exist_ok=True)
with open(fnAbs, 'w', encoding='utf-8') as f:
    f.writelines(header_lines)
# Append the pandas dataframe to the file (No headers, no index)
out_df.to_csv(fnAbs, mode='a', header=False, index=False, encoding='utf-8', lineterminator='\n')
def convertTo8760(dfIn: pd.DataFrame) → pd.DataFrame:
Takes a dataframe of any time length (e.g., a 3-day measurement) and resamples
it into exactly 8760 rows. The start_time and end_time are strictly preserved
from the original data. The delta-time is automatically calculated to fit
exactly 8760 evenly spaced rows between start and end.
Missing or new intermediate values are time-interpolated.
:param dfIn: Input DataFrame containing a 'date_st' column.
:return: DataFrame with exactly 8760 rows.
# 1. Create a copy and set the datetime index
df = dfIn.copy()
if 'date_st' not in df.columns:
    raise ValueError("The DataFrame must contain a 'date_st' column.")
df['date_st'] = pd.to_datetime(df['date_st'])
df.set_index('date_st', inplace=True)
# Sort index and remove duplicates just to be safe
df.sort_index(inplace=True)
df = df[~df.index.duplicated(keep='first')]
# 2. Extract the exact start and end times from the original data
start_time = df.index.min()
end_time = df.index.max()
# 3. Generate exactly 8760 evenly spaced timestamps between start and end
# Pandas will automatically calculate the required delta-time to fit 8760 periods.
target_index = pd.date_range(start=start_time, end=end_time, periods=8760)
# 4. To interpolate accurately, we combine the original timestamps with the new ones.
# This ensures the original anchor values are present for the math calculation.
combined_index = df.index.union(target_index).drop_duplicates().sort_values()
df_combined = df.reindex(combined_index)
# 5. Interpolate the missing values based on exact time distances
df_combined = df_combined.interpolate(method='time')
# 6. Extract ONLY the 8760 target timestamps
df_8760 = df_combined.loc[target_index].copy()
# 7. Edge-case handling (Forward/Backward fill in case of extreme edge NaNs)
df_8760 = df_8760.bfill().ffill()
# 8. Reset the index so 'date_st' is a normal column again
df_8760.index.name = 'date_st'
df_8760.reset_index(inplace=True)
# Final validation
assert len(df_8760) == 8760, f"Error: Result has {len(df_8760)} rows, expected 8760."
return df_8760
Hi everyone,
I have now tried generating the EPW file using the code. After inspecting the saved .wea file and the log, I have come to the following conclusion:
Is it possible that HB Annual Daylight, regardless of the timestamps contained in the EPW file, always uses the full 8,760 hours of the year from 1 January 00:30 to 31 December 23:30? This would mean that the solar zenith and azimuth angles are calculated according to the conventional annual hourly sequence, which then leads to the error in gendaymtx.c at the following lines of code:
Furthermore, does HB always assume this sequence in standard time? If so, this would imply that any EPW file whose data columns deviate from the sequence yyyy,1,1,30 to yyyy,12,31,24,30 would result in a more or less significant error in the calculation of solar zenith and azimuth angles and thus the optical quantities with the enhanced two-phase method.
Am I correct in this assumption? If so, it would not be possible to use custom EPW files for simulation in this way. Is there an other way to validate HB Annual Daylight with a custom EPW file?
Best regards,
Simon
I found out a solution with the help of @sarith. Thanks for that. Now sub-minute calculations and custom wea files are possible to calculate.
Feel free to contact, in case you have the same problem.
Kind regards
Simon Weber, M.Sc .
Research Associate
Institute for Acoustics and Building Physics
Pfaffenwaldring 7
70569 Stuttgart
Germany
Tel: +49 711 685 66301
E-Mail: simon.weber@iabp.uni-stuttgart.de
Website: http://www.iabp.uni-stutt gart.de
https://orcid.org/0000-0002-6 268-8547
