Vertical Sky Component - multiple legends
vertical_sky_component_box.gh (491.1 KB)
Dear All,
any idea how to remove multiple of legends that are being create for each analyzed surface. We would like to have only one color legend when evaluating number of facades (buildings) as otherwise the graphic is not very clear.
@janak It is a simple question. If you have multiple analyzed surface, you should flatten the testpoints\ptsvectors\facemesh. After finished the analysis,you should check the results.If results are in data tree,you should flatten the tree.
Here is a demo gh file.
combine many legends in one.gh (544.1 KB)
Good luck for you!
Thanks a lot for help. As I am new to L+H I would appreciate very much if you could implement your suggestions into my VSC script?vertical_sky_component_box.gh (491.1 KB)
