Vertical Sky Component (VSC) analysis
Hi All,
I’m looking to produce a Vertical Sky Component analysis in line with BRE BR209: Site Layout Planning for Daylight and Sunlight - 3rd Edition. I’ve modified a recipe using the sky view tool in honeybee and used a simple geometry to test. I’ve managed to produce results however, I’m wanting to make reporting the results easier. Is there a way I can overlay the opening identifiers over the windows to make it easy to match the results to the opening? I also want to export the results to Excel, I’ve been copy and pasting from a panel, and was wondering if there was a more streamlined way to do this? I also want to be able to compare existing results with new results in line with BRE guidance, is there a way to achieve this, within Grasshopper?
