I am doing sunlight hours analysis. When the mesh is generated for the overall analysis, is there a way to output the data on the mesh itself?
Additionally, is there a way to generate a chart for each month to show a detailed breakdown?
Hello @hmurya. For data visualization on mesh you can use tag 3dtext component.
For the monthly chart you can try using analysis period or you can filter data using native grasshopper components.
Oh wow, it was as simple as that. thanks a lot!
