I was just wondering if there was a limit to the amount of points that can be put into the _plane input of the ladybug ViewRose component?
To be a little more specific, when I use multiple points, some points start producing incorrect results. Individually, these results are correct, but trying to perform them all through one process, it starts seeing through walls, and some angles work through certain walls when others don’t?!
