View study simulation
Hi, I’m doing a view study on V1.3.0. The result seems all good, except for one area, showing circle below, which should have lower visibility %.
I’m not sure I understand what you’re asking here. I don’t see a circle in your image. Could you elaborate?
@chris
Thanks, @YD , but I’m not sure that I follow. Why do you think those areas should have a lower view %?
Hi Chris, for the bottom circle, the left hand side is a solid wall, while window 1 and 2 are giving lower than 100% view, so I think that area should have less than 100% view.
