Hi @mostapha and @chris,
I get in to this one today: I’m separating HB zones by program. The i define windows for each zone according to their program (see blue groups in attached) At the end of the process i want to vizualize the resulting zones with their windows with the HB_decomposeByType component. And here is when the issue appears. The component fails with the followinf error:
Runtime error (KeyNotFoundException): 330db659-0689-4344-ba17-d91a9c08efc0
Traceback:
line 8474, in visualizeFromHoneybeeHive, “”
line 103, in main, “”
line 161, in script
Connecting separately the zones by program seems to work. But when i connect all of them together it fails. It is not that the results is not there. When i see the resulting geometry with the wireframe component everything is there.
My assumption is that something is messed up in the process of separating the zones.
This goes beyond my capabilities to deal with such error types.
Looking inside the clusters show that the geometry is created fine. Need to say also that sometimes i need to recalculate (disable/enable) the cluster component in order for it to work.
I’l appreciate your help on this one. I expected this process to work flawless … and here i am
Visualize from HB Hive Bug_Problem.gh (698.7 KB)
